search and split the string
N00001D2312T140402N00002D2312T140403N00003D2312T140403N00004D2312T140404N00005D2312T140404N00006D2312T140404N00007D2312T140405N00008D2312T140405N00009D2312T140405
i have this data i want to split it to 72 character  and put a end line
 some thing like this below:
N00009D2312T140405
currently i just have few data if in future i will have much... plz help. thk u
Message 1 of 22
(12,266 Views)
a. Create a while loop.
b. Find the string length and use that number for number of iteration that you need.
c.Use String Subset to break the string into parts,
d. use carriage return or line feed constant in the string palette and concatenate with the string subset using concatenate string vi again in the string palette.
Message 2 of 22
(12,263 Views)
thks but i still confuse , can i get an example for this plz...thk u
Message 3 of 22
(12,255 Views)
Hi Jeyanthi,
There is a number of way to do that. I have attached one possible way. I hope it helps.
Aman
Message Edited by aman_bajra on 12-26-2008 11:34 PM
Message 4 of 22
(12,251 Views)
aman_bajra, there is a problem with your proposed solution : the resulting string contains only the last chunk of data, with a probably unwanted terminal CR.
You need to test the length of the splited string before adding or not a CR, and concatenate the string using a shift register...
Message Edité par chilly charly le 12-27-2008 04:02 PM
Chilly Charly    (aka CC)
Message 5 of 22
(12,218 Views)
Hi
i have one similar problem. i explain : i have for example some string like that
"<pays> Finland </pays> <ville> Tampere </ville> <temperature> 17~C </temperature> <ensoleillement> Nuageux </ensoleillement>" (xml code).
And i want my programme just give me:
" Finland Tampere 17~C Nuageux ".
In the qim to published it.
I used some cluster for my string some for loops but i haven´t succeeded.
An other problem is i don´t know all the time when i have to split, the lengh of the string is variable so i can´t do as you do. I mean to split all the 72 char for example. I tried many thing but i really have great difficulty to do that. I have really not anymore ideas how to do that.
So please help me i am becoming crazy because of that one.
PLEEEEEEEEEEEEEEEEEEASE 🙂
thank you so much
BaccAdr
Sorry for my english i am a french student on a finnish keyboard Smiley Mad
Message 6 of 22
(11,063 Views)
Hi Bacc Adr,
Check the attached VI. I think it will solve your problem..
Nitzz
(Kudos are always Welcome;))
Message 7 of 22
(11,050 Views)
Hi Nittz,
Your code could be simplified using Regular Expressions as shown below:  (bottom code)
The solution is more flexible as it does not hard code how many tags to remove.
Message 8 of 22
(11,043 Views)
I found out I had a Rube Goldberg of my own!!!
Thanks to Darin for the improvement.  Amazing what can be done with a boolean 😉
LOL!
Message 9 of 22
(11,015 Views)
Hi both of you,
This is almost perfect and you are (almost) both god for me, I will analyze precisely that soon ( but Ray R i did not have time to use you because at home i have only LV 7.1). But small problem wich stay with the first big, it´s i said
"<pays> Finland </pays> <ville> Tampere </ville> <temperature> 17~C </temperature> <ensoleillement>Nuageux  </ensoleillement>"
just as example but it could be totally random, so the data could be longer as
"<pays> Finland </pays> <ville> Tampere </ville> <temperature> 17~C </temperature> <ensoleillement> Nuageux  </ensoleillement> <date>5 mai </date> <time> 3:00 pm </time>"
or shorter.
But don´t worry I will try to find a solution and if i have a HUGE problem I would come back to you.
I don´t know if you just come to make this one but it´s really impressive. The function you used are well concatenate string & match pattern ?
THAAAAAAAAAAAAAAAAAAAAN YOUUUUUUUUUHOUUUUUUUUU so much Smiley Happy
Best regards
BaccAdr
Message 10 of 22
(11,004 Views)
