search and split the string
Hi both of you,
This is almost perfect and you are (almost) both god for me, I will analyze precisely that soon ( but Ray R i did not have time to use you because at home i have only LV 7.1). But small problem wich stay with the first big, it´s i said
"<pays> Finland </pays> <ville> Tampere </ville> <temperature> 17~C </temperature> <ensoleillement>Nuageux  </ensoleillement>"
just as example but it could be totally random, so the data could be longer as
"<pays> Finland </pays> <ville> Tampere </ville> <temperature> 17~C </temperature> <ensoleillement> Nuageux  </ensoleillement> <date>5 mai </date> <time> 3:00 pm </time>"
or shorter.
But don´t worry I will try to find a solution and if i have a HUGE problem I would come back to you.
I don´t know if you just come to make this one but it´s really impressive. The function you used are well concatenate string & match pattern ?
THAAAAAAAAAAAAAAAAAAAAN YOUUUUUUUUUHOUUUUUUUUU so much Smiley Happy
Best regards
BaccAdr
Message 11 of 22
(2,587 Views)
If the number of tags are random you can get the number of tags like this.
Nitzz
(Kudos are always Welcome, Mark as solution if it is the One;))
Message 12 of 22
(2,578 Views)
Hi BaccAdr,
is your data from a "real" xml file? In this case i would use some xml functions to get the data i need.
Mike
Message 13 of 22
(2,577 Views)
i did not used it for the moment, but i think it will be real xml data. But what is this function so talk about ?
And for the other programs i just would like to be sur of the "Match Pattern" & "Concatenate Strings" ???
i am on the succes road ... BECAUSE OF YOUUUUUU
Message 14 of 22
(2,572 Views)
I tried Ray.R's code and it works regardless of how many tags you have in your input string.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 15 of 22
(2,569 Views)
i apologyze i öust be tired of working on it but i try the one i join but it´s unroking. Do i make something wrong, do i don´t understand something ?
Message 16 of 22
(2,562 Views)
Here you go. LV2010. If you haven't got 2010 you can just look at the picture below.
Front Panel        Block Diagram
P.S! this is Ray.R's code which he posted in a previous post. I just implemented it in the VI you posted
Even
Topro AS
Norway
Message 17 of 22
(2,558 Views)
i don´t know why i have some random new line new lines all time.
i i did it again myself and same problem
i think i will put it in array after, and i would like to understand all before to continue
thank
Message 18 of 22
(2,551 Views)
can you post your actual code instead of a picture?
Did you develop it using LV7.1?  if not, let us know which version you are using.
By the way, the example I posted will take any number of tags.
Message 19 of 22
(2,546 Views)
i worked with LV 10 but on my own laptop i have the 7.1.
i try to have a clear idea of all this program you gave me because it bit shacked in my head. i try to understand all of the one you give me.
so i can read both 7.1 and 10 of labview
Message 20 of 22
(2,538 Views)
