search words in a excel file
If the number pages are going to be the same you can use FOR loop.
What you can do is, when you find the word, just stop the for loop (Using conditional terminal), no need to keep searching in other pages, unless you want multiple occurrence of the word.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 21 of 50
(1,682 Views)
but where i must insert the word i want find?
Message 22 of 50
(1,681 Views)
Create one control to enter search string, data is the 2D array you are getting from excel,
check your string in 2D array, if you want to replace, select the index and insert appropriately.
Aarthi
Message 23 of 50
(1,679 Views)
Accepted by alan4
Check this one now...
I guess now you should be clear how to search and all.
I have not fully tested it, but I guess it is a start point for you
Gaurav k
CLD Certified !!!!!
Message 24 of 50
(1,677 Views)
Hi Gaurav,
   I just want to know the vi which i posted using Find And Replace VI is correct or not?
Aarthi
Message 25 of 50
(1,673 Views)
thats perfect GAK!!!!!!
that is what i need!!!!nut one question my excel file have 7 columns andwith this only i can see the first 3 columns..why?
Message 26 of 50
(1,671 Views)
Change the range to read from A1:C15 to A1:G15.
This is basically FromCellNo:ToCellNo
A refers to column in excel and 15 is for row.
Now you can read 15 rows only.Change it accordingly
Aarthi
Message 27 of 50
(1,665 Views)
ok i have isntert it in a while, for read all lines...thats good!!!
and now i must save the file after doing the changes!
Message 28 of 50
(1,659 Views)
Hi Aarthi,
The method which you have posted is right if there is only one occurrence of word you are searching.
If you run this code problem which I see is,
say you are searching "Traction" and replace string is "XYZ"
cell A1 contains  abcd_Traction
cell A2 contains Traction
Result of your code will be
A1= abcd_XYZ
A2= Traction
And one more doubt I have (Which I have not checked) is , it will search in only one sheet (Active) and not all. But I am not sure about it. Let me know if you have tried this or if you try.
Gaurav k
CLD Certified !!!!!
Message 29 of 50
(1,656 Views)
Hi Gaurav,
   I will check that replace string, i am not aware of that. And also for selecting worksheet
we have Get worksheet function in which we can select sheets, this i have not tried for this function,
but i have worked for some other functions. Let me try and let you know.
Aarthi
Message 30 of 50
(1,647 Views)
