search words in a excel file
that the example i want to read...i think you will help me, i am using labview 2009
and i want to search for example: Dev5/ai3
thats all..
Message 11 of 50
(1,262 Views)
May be this vi helps, search in text can be done by selecting the type as string.
Here is the attachment. Is this the one you want?
Also Gak, i am here to learn new things.I will not take it offensive and also
i have not worked with formulas in excel from labview. I will explore it. Smiley Happy
Aarthi
Message 12 of 50
(1,263 Views)
thanks aarthi!!!but i haven't got the NI_excel.lvclass....
so i can't work with this...
Message 13 of 50
(1,262 Views)
Ya you told in the last post, i forgot that.
As we discussed, try using ActiveX.
Can you post your vi? How you are retrieving from file?
Aarthi
Message 14 of 50
(1,260 Views)
can you tell me where in where module is the error that appears me??? that i don't have the lvib....
Message 15 of 50
(1,259 Views)
Do you have report generation toolkit?
Aarthi
Message 16 of 50
(1,258 Views)
no i don't
Message 17 of 50
(1,255 Views)
Hi Alan,
Please find attached code, to access excel using ActiveX. Open Trial1.vi. (for Example)
You can read data search string (As explained in one of the post, to use for loop n all). If you find then stop loop, else change sheet number and continue search.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 18 of 50
(1,253 Views)
so i cant pass the pages automaticly,
can be with a for?
Message 19 of 50
(1,251 Views)
in the vi you have send me, i don't know how to search something... where i insert the string i want to find??
if i change the range appears an error...
Message 20 of 50
(1,250 Views)
