search words in a excel file
Hi Gaurav,
   As you told i have checked that replace string option. It works as you told.
It is not matching exact occurance.
Also this function will search in active sheet only, but we can select worksheet by Excel Get Worksheet function
and then we can search.I have checked it.
Aarthi
Message 31 of 50
(1,112 Views)
@ Aarathi: Thanks for informing.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 32 of 50
(1,103 Views)
and how can i do to search, change and save but in other place, not automatically the overwrite the original excel??i change the workbook but i can't save...
i am alan4 partner
Message 33 of 50
(1,089 Views)
Instead of "Save" invoke method, use "Save As". Smiley Wink
Gaurav k
CLD Certified !!!!!
Message 34 of 50
(1,085 Views)
yes but automatically if i put saveas there is a dialog that appears and whati want is to put a direction and save it...
Message 35 of 50
(1,083 Views)
Post your code
Gaurav k
CLD Certified !!!!!
Message 36 of 50
(1,081 Views)
thats your code trial1, you have attached in the third page...
Message 37 of 50
(1,072 Views)
If you do not want the Dialog box, give input to "Filename" (Intended path).
Gaurav k
CLD Certified !!!!!
Message 38 of 50
(1,071 Views)
hi!!
i have one question, in stead of doing new file..can i do something that doesn't save nothing, like virutal or temporary file??
whati want is to read an original excel change something, and read the file i have change...
do you understand??
Message 39 of 50
(1,060 Views)
NO Smiley Indifferent
Gaurav k
CLD Certified !!!!!
Message 40 of 50
(1,058 Views)
