02-13-2012 01:01 AM - edited 02-13-2012 01:02 AM
Hi Gaurav,
As you told i have checked that replace string option. It works as you told.
It is not matching exact occurance.
Also this function will search in active sheet only, but we can select worksheet by Excel Get Worksheet function
and then we can search.I have checked it.
02-13-2012 02:45 AM
@ Aarathi: Thanks for informing.
02-15-2012 05:41 AM
and how can i do to search, change and save but in other place, not automatically the overwrite the original excel??i change the workbook but i can't save...
i am alan4 partner
02-15-2012 05:53 AM
Instead of "Save" invoke method, use "Save As". ![]()
02-15-2012 05:56 AM
yes but automatically if i put saveas there is a dialog that appears and whati want is to put a direction and save it...
02-15-2012 05:57 AM
Post your code
02-15-2012 06:04 AM
thats your code trial1, you have attached in the third page...
02-15-2012 06:05 AM
If you do not want the Dialog box, give input to "Filename" (Intended path).
02-17-2012 02:37 AM
hi!!
i have one question, in stead of doing new file..can i do something that doesn't save nothing, like virutal or temporary file??
whati want is to read an original excel change something, and read the file i have change...
do you understand??
02-17-2012 02:41 AM
NO ![]()
