searching a file in the disk
Hello and greeting from your friend,
I'm looking for a command or a small programme wich serachs files by their names in directories and returns a boolean value, true if that file exist and false if not.
Message 1 of 18
(4,376 Views)
If you really want to do that in LabVIEW, you can with the OpenG VI List Dir Recursive :
hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 18
(4,347 Views)
Maybe the "Check if File or Folder Exists" function in LV is better suited given the path to the source is already known and shall be checked.
Otherwise, i would use "Recursive File List" directly from LV since it does not require you to install OpenG.
On the other hand, OpenG brings a lot of additional, nice functions so it could still make sense......
Norbert
Norbert
Expert: Geometry
Message 3 of 18
(4,343 Views)
Thank you very much Dears,
@TiTou
The OpenG VI seems very interesting, but I can download that library, please bring me another links !
Your solution works well. But I need one more thing please ... I want to search all files whose name begins or ends with "Toto" for example. Is it possible in Labview ??
Message 4 of 18
(4,332 Views)
Accepted by topic author za3im_ensa
You can use the recursive file list function to create an array of filenames. Then do a string search within this array:
Your regalar expression would be "^Toto". Refer to the help of "Match Regular Expression" primitive for further help on regular expressions. Also you can look here in the forums since this is a regularily discussed topic and, sadly, not too easy to begin with....
Norbert
Norbert
Expert: Geometry
Message 5 of 18
(4,325 Views)
Mr ,
Thank you, It's so kind of you
Could I have the vi file of your last programme ?
Best regards
Message 6 of 18
(4,310 Views)
I dont like posting VIs on the forums since it is my experience that users simply use those examples as ready-to-go-solutions without analyzing the code...
Nevertheless, this is my one-per-year-exception.
Norbert
Norbert
Expert: Geometry
Message 7 of 18
(4,306 Views)
hhh tkank you very much, although I can't enjoy your program because i'm using juste the 2010 version.
It does not matter, I'll manage.
Have a nice day.
Cordially
Message 8 of 18
(4,295 Views)
In LV 2010 the VI would be a little more tricky since i use the conditional indexing tunnel which is a new feature to 2012.
Still, it is doable, but you have to process the result array in a more complicated way. Either you put only the valid filepaths into the array at all (requires shift register and build array function) or you put one entry in each iteration into the array and delete invalid entries in a postprocess. The later option works with an autoindexing tunnel, but requires you to differ between valid and invalid entries (similar to what i did). For invalid values, put an empty string into the autoindexing tunnel.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 9 of 18
(4,268 Views)
Hello dear Norbert,
Right now, I can't translate your propositions to vi programme. But I still searching until find solution;
best regards.
Message 10 of 18
(4,250 Views)
