select channel !!!
Hi!
I have to select many channels from DIO-6503. Each channel is predefined in my system. When I select a channel in program once it doesn't stay permanently if I close program and start again.
So when I am reopen program, I have to select again that channel from the program.
my question is how to keep selected channel like dev2/port0/line0 permanently while i am opening program so need to select channel again.
thanks
(3,002 Views)
Perhaps I'm misunderstaning the question, but have you simply tried making the control's value be the default value and saving the program? Right-click on the control, and select "Make current value default". Save.
(2,990 Views)
Additionally, you could use the same function in the 'Operate' menu to set the current state of all front panel controls to be defaults.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,971 Views)
