01-03-2007 10:06 AM
01-03-2007 10:20 AM
01-03-2007 10:26 AM
01-03-2007 10:32 AM
Ok, in that case I'll help. You would need 12 channels on a board to get 4 differential and 4 RSE channels. You don't need a separate channel for ground. Take a look at some of the products NI sells and you'll see they are specified as 16 single ended/8 differential.
As far as the other question, it should be 500 / 8 = 62.5 KHz. Although the question says, "What is the maximum..." The maximum is 500 KHz if it's a simultaneously sampling board. Of course this will change if you mix RSE and differential channels. Maybe someone else can shed more light on this one.
01-03-2007 10:43 AM
01-03-2007 10:49 AM - edited 01-03-2007 10:49 AM
The maximum signal frequency will be half the maximum sample rate of your board (according to nyquist's theorem).
The maximum signal frequency of each channel depends on the achitecture of your card. There are two possibilities:
I would guess the architecture the question is refferring to is the Multiplexed architecture.
Message Edited by SarahB on 01-03-2007 10:52 AM
01-03-2007 12:01 PM
