select multiple items in tree control
In the attached LabVIEW 2018 SP1 application, if I double click an item in "Default Tree Control", its data is plotted in a graph. How do I double click multiple items in "Default Tree Control" so that their data are plotted in the graph?
(3,414 Views)
You can't double-click multiple items.  But you can select multiple items, then right-click to get a context menu (which you can customize) and select a 'plot' function.
(3,373 Views)
Hello Paul,
I can't use Shift or Ctrl key to select multiple items. Can you elaborate in detail ?
cha@bellflight.com
(3,367 Views)
cha@bellflight.com wrote:
Hello Paul,
cha@bellflight.com
(3,348 Views)
Hello Paul,
The attached LabVIEW 2018 SP1 application (version 01) works! However, I can't use Double Click as an Event Case for selecting multiple items for graphical display. Is "Value Change" the answer ?
(3,309 Views)
Hello Paul,
No.  As I already told you:
(3,301 Views)
Hello Paul,
Sorry for this delay. I was busy with another task. Attached is the latest version 02 that works!
(3,268 Views)
