selecting OPC item with LabVIEW Frontpanel DataSocket there start installer for previous LabVIEW version
I´ve a simple problem in my LabVIEW settings (I think)
I´ve a programm in LabVIEW some items with Frontpanel Datasocket When I want to connect a OPC Item to the FrontPanel Element, there start a Installer, which want to Install a Runtime Version of a previous LabVIEW Version (I programm in LabView 8.5.1., and there start a installer for LabVIEW Runtime 7.1.1
I get the message please wait, while windows configurers NI LabVIEW Runtime Engine 7.1.1.
Normally there should be the menu for selecting the OPC item for this Frontpanel element
I´ve programm some days at this computer without these problems before this error appears, so I think there is a wrong setting.
The detailed error message can be seen in the screenshot
(2,730 Views)
this sounds strange. Have you installed any other software so that this might have caused this wrong behavior? I think that you should deinstall all NI software and install it new.
Torben
Message Edited by TorbenP on 12-03-2008 08:01 AM
(2,713 Views)
