selecting an array of strings to go to a html document
I am trying to make it to where when I select an array object it will send it to an html document the only problem is it is an infinit array, so i can send a finite to a HTML document but infinit I can not.
here is the code.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(2,886 Views)
Accepted by Harold_Timmis
Hi Harold,
you can use a for loop with a case structure inside of it.
Mike
Message Edited by MikeS81 on 04-03-2009 09:52 AM
(2,881 Views)
perfect, I need to read up on my for loops I know how to use them in C++ but i geuss it is different in labview
thank you
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(2,867 Views)
Not really. Loops are loops are loops. LabVIEW loops have the capability of autoindexing, which is what Mike is using in his example. This is equivalent to a "foreach" statement in text-based languages.
(2,833 Views)
