selecting particular data after visa read is done.
hello everyone,
Can i select the particular  data after visa read and mask other output data?
Message 1 of 15
(2,250 Views)
Hi jeet,
Yes.
(This usually is called "parsing". You need to apply the rules given in the manual of your device.)
Message 2 of 15
(2,242 Views)
hello thank you for quick reply.
As attached in the image i want to neglect 1A and OK from this output data and want to select only the 042D. how is is possible.??
Message 3 of 15
(2,228 Views)
Hi jeet,
Use ScanFromString with a formatstring of %2s%4s and use the 2nd output.
When the desired part is a hex-formatted number you can also use %2s%04x instead…
Message 4 of 15
(2,224 Views)
I did not get you actually. can you explain in detail if possible. or with example
Thank you
Message 5 of 15
(2,210 Views)
Hi jeet,
When you don't know how to use ScanFromString function you should take the LabVIEW basics/tutorials offered at the top of the LabVIEW board…
Use ScanFromString with a proper format string:
Message 6 of 15
(2,193 Views)
Thanks. i will go through scan function. Moreover  As this function is for scan. my sensors values are going to change. this will applicable for every hex value which is going to change? i want to  neglect 2 LSB's in hex output and all the raw data such "ok" .
Looking forward for help.
thank you
Message 7 of 15
(2,180 Views)
Hi jeet,
As long as the format stays constant the ScanFromString will correctly parse your string.
That's the point of a "fixed format"…
What are "2LSBs in hex output"? I only know of LeastSignificantBits in bytes/words…
What is "least significant" in your string of chars?
The "ok" (or "OK" in your image) is already omitted in my example, it should appear in the "remaining string" output of SfS…
Message 8 of 15
(2,172 Views)
Im attaching  the new image in here. So in this i want to remove all the data such as A -trans -crc b800, 1A(in hex number), Ok, SIC-CLI. overall all i just want to select 042B in the the whole image.  and olny 042B will change after every sensor output others will remain same. do you have any idea how to do it?
:here LSB are 1A
Thank you for helping me out
Message 9 of 15
(2,168 Views)
Hi jeet,
@User002 wrote:
So in this i want to remove all the data such as A -trans -crc b800, 1A(in hex number), Ok, SIC-CLI. overall all i just want to select 042B in the the whole image.  and 1A042B will change after every sensor output others will reamin same. do you have any idea how to do it?
What is the communication protocol with your device?
When does it send those data?
Is there some trigger/request for each of those lines?
Does the line of interest ALWAYS start with "1A"? In case it does not: is there a better format description for those two bytes?
You really need to learn to supply all the information needed to answer your questions!
Now you completely changed the problem from a fixed format string to a completely different kind of string…
You already got the very same question in your other thread: Please supply a full specification of your communication protocol!
Why does your µC answer with such a lot of garbage when you just request some data?
Message 10 of 15
(2,152 Views)
