selecting particular data after visa read is done.
----The micro controller is already programmed like this so im getting this output like this raw data with hex output.
Q1:--- Mc is connected to PC using USB
Q : 2--- after sending all the commands in Solved: Re: sending multiple commands at once using visa write and visa read - Page 2 - NI Community this link i will get this is the final output.
Q3: there are 14 commands and each commands should be send to the Mc( each command has different output but now im just care about the last commands output and as image shows the output of last command). in case if i dont send all the commands then output will not update.(so this is fixed command string which id commands)
q4: yes it always starts with 1A but last 4 values are changing.
Message 11 of 15
(655 Views)
Hi jeet,
  • Read the µC responses line by line.
  • Check for "1A" as first two chars.
  • If found read the next 4 chars, else omit that line…
Message 12 of 15
(638 Views)
thanks. will do that and ask you if i have any doubts.
Message 13 of 15
(635 Views)
hi,
Can you tell me? how can i proceed further to select four char and eliminate other all the chars. (im using match pattern to compare strings with 1A so it is elimanating all the charathers after  1A)
Message 14 of 15
(618 Views)
hello it worked. i used two match patterns to remove the before and after values of my string
Message 15 of 15
(595 Views)
