send command to modem using serial port and capture the response in the labview
Dora,
Take a look at the "Basic Serial Write and Read" vi example. Search for it using the Example Finder. Use that as a starting point. There are several other examples, too.
Ed
Message 11 of 12
(638 Views)
I am not good at LabVIEW programming So sad.
Actually we learnt little over past two years. But we need to complete the project by ourselves.So I needtoputmoreefforts.
We are using BluOcean GPRS modem for this project. The baud rate is 19200
I will try to make some changes according to your ideas next Monday.
I did't bring modem with me because it belongs to my school.
So i will test it next Monday and tell you how is it.
Thanks a lot.
Message 12 of 12
(621 Views)
