send command to shelly
i bought a shelly (https://shelly.cloud/shelly-plus-1/) and i want to control with labview
When i send the command like it's on the image, it works but allways open a new browser window
it is possible to send this command without open a browser window?
(2,938 Views)
Accepted by lmrmendes
The name of the vi is Open URL in Default Browser...
Most probably, you need to use one of the vis in the palette Data Communication -> Protocols -> HTTP Client
Paolo
(2,922 Views)
Paolo Many thanks
it works
(2,907 Views)
hii,
I have an shelly smart plug and temperature sensor. i want to control this devices with labview . can you suggest me how did you do that. how did you send the signals from shelly divices?
(1,797 Views)
