sending data throughTCP/IP to an Labview server.
I'm trying to send a string from an arduino gsm board  to an labview server. From arduino board i think everythink is ok, i specified ip adress and port number, the problem is that it can't connect to the labview server and i don't have any more ideas where can be the proble.
I tryed with hercules to listen o port and it works fine, i received the data from arduino.
I leave here the code i used and the VI for server.
// libraries
#include <MKRGSM.h>
#include <Arduino_MKRENV.h>
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[]     = "1234";
// APN data
const char GPRS_APN[]      = "live.vodafone.com";
const char GPRS_LOGIN[]    = "live";
const char GPRS_PASSWORD[] = "";
// initialize the library instance
GSMClient client;
GPRS gprs;
GSM gsmAccess;
uint8_t pachet[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
// URL, path and port (for example: example.org)
char server[] = "141.85.162.154";
char path[] = "/";
int port = 5901; // port 80 is the default for HTTP
void setup() {
  // initialize serial communications and wait for port to open:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  if (!ENV.begin()) {
    Serial.println("Failed to initialize MKR ENV shield!");
    while (1);
  Serial.println("Starting Arduino web client.");
  // connection state
  bool connected = false;
  // After starting the modem with GSM.begin()
  // attach the shield to the GPRS network with the APN, login and password
  while (!connected) {
    if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &&
        (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
      connected = true;
    } else {
      Serial.println("Not connected");
      delay(1000);
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, port)) {
    Serial.println("connected");
    // Make a HTTP request:
//    client.print("GET ");
//    client.print(path);
//    client.println(" HTTP/1.1");
//    client.print("Host: ");
//    client.println(server);
//    client.println("Connection: close");
//    client.println();
 client.beginWrite();
 client.write(pachet, sizeof(pachet));
 client.endWrite();
  } else {
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
void loop() {
  // read all the sensor values
  float temperature = ENV.readTemperature();
  uint16_t word_temp = temperature * 100;
  uint8_t high_word_temp = word_temp >> 8;
  uint8_t low_word_temp = word_temp;
  pachet[1] = high_word_temp;
  pachet[2] = low_word_temp;
  float humidity    = ENV.readHumidity();
  uint16_t word_hum = humidity * 100;
  uint8_t high_word_hum = word_hum >> 8;
  uint8_t low_word_hum = word_hum;
  pachet[3] = high_word_hum;
  pachet[4] = low_word_hum;
  float pressure    = ENV.readPressure();
  int16_t word_pressure = pressure * 100;
  uint8_t high_word_pressure = word_pressure >> 8;
  uint8_t low_word_pressure = word_pressure;
  pachet[5] = high_word_pressure;
  pachet[6] = low_word_pressure;
  float illuminance = ENV.readIlluminance();
  uint16_t word_illuminance = illuminance * 100;
  uint8_t high_word_illuminance = word_illuminance >> 8;
  uint8_t low_word_illuminance = word_illuminance;
  pachet[7] = high_word_illuminance;
  pachet[8] = low_word_illuminance;
  float uva         = ENV.readUVA();
  uint16_t word_uva = uva * 100;
  uint8_t high_word_uva = word_uva >> 8;
  uint8_t low_word_uva = word_uva;
  pachet[9] = high_word_uva;
  pachet[10] = low_word_uva;
  float uvb         = ENV.readUVB();
  uint16_t word_uvb = uvb * 100;
  uint8_t high_word_uvb = word_uvb >> 8;
  uint8_t low_word_uvb = word_uvb;
  pachet[13] = high_word_uvb;
  pachet[14] = low_word_uvb;
  float uvIndex     = ENV.readUVIndex();
  // print each of the sensor values
  Serial.print("Temperature = ");
  Serial.print(temperature);
  Serial.println(" °C");
  Serial.print("Humidity    = ");
  Serial.print(humidity);
  Serial.println(" %");
  Serial.print("Pressure    = ");
  Serial.print(pressure);
  Serial.println(" kPa");
  Serial.print("Illuminance = ");
  Serial.print(illuminance);
  Serial.println(" lx");
  Serial.print("UVA         = ");
  Serial.println(uva);
  Serial.print("UVB         = ");
  Serial.println(uvb);
  Serial.print("UV Index    = ");
  Serial.println(uvIndex);
  Serial.print(" ");
   Serial.println(" ");
  for(int i=0; i<28; i++)
//    if(pachet[i]==0)
//        pachet[i]=1;
    Serial.print(pachet[i]);
    Serial.print(" ");
  Serial.println();
  Serial.print("dimenziunea pachetului este");
  Serial.println(sizeof(pachet));
  // print an empty line
  Serial.println();
  // wait 1 second to print again
  delay(1000);
  // if there are incoming bytes available
// from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.available() && !client.connected()) {
    Serial.println();
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    for (;;)
(1,283 Views)
Hi Dummson,
Unfortunately you forgot to attach that VI…
Can you create one more VI that does the same as the Arduino should do: send some data to your "LabVIEW server" (whatever that is!?)?
(1,255 Views)
