Scan/search hex string with wild card
Is there a better way to do this? I need to search incoming hex from rs485 for this pattern FFEx. This is a hex string, not normal, so I couldn't find a way to use a wildcard to search the string. Attached is what I came up with, but it seems excessive.
(1,608 Views)
Accepted by topic author TheWolfmansBrother
We probably need a more specific example. I would assume that a typical input string is longer than 2 bytes, else you could just use "search array" here.
If it is exactly 4 bytes, casting to U16 and doing a masking/comparing would work.
(1,599 Views)
It's only the four bytes. Your solution works perfectly, a lot less cumbersome. thank you. I tried the type cast, earlier, just wasn't quite getting it correct.
(1,571 Views)
