sending data to a computer with ni 9795
I have come across the NI 9795 and it seems like the perfect solution I was looking for.  I am wanting to log data from a vehicle while the vehicle is in use and have it be sent to my computer for example.  The other module I will be using is a NI 9853 with FPGA.  I know the gateway module must be used in scan mode.  I have read about using the cRIO in hybrid mode but I wanted to ask if what I am wanting to do is possible with the NI 9795.  Also, are the measurement/ end nodes needed if I am only wanting data from the vehicle?  Thank you.
(2,630 Views)
the 9795 is a WSN gateway for the cRIO platform and can only be used to communicate with the WSN nodes by using ZigBee. If I understand you correctly you want to stream data from the integrated cRIO in your vehicle to a computer elsewhere? How many meters do you have between the vehicle and your computer. I would assume to adapt wireless LAN by using standard hardware to your cRIO ethernet port and communicate with TCP/UDP, network streams or any other communication strategy you want with your PC.
Tyler
Certified LabVIEW Architect
(2,615 Views)
