separate non zero indices from a 2d array
Hi all,
Please find the excel data attached to the post, its a 2d array data. i have to find the index values of rows and columns with 1's and display it.
KM
(3,174 Views)
Kamasani,
What did you implement up till now?
Did you at least think about a possible approach/algorithm to solve your requirements?
We can help you if you are stuck in an approach, but we don't have the task to implement a solution for you...
Norbert
Norbert
Expert: Geometry
(3,162 Views)
moreover, your .xlsx file is corrupt
(3,132 Views)
