How to solve Error -1074396080 occurred at IMAQ array to color Image
I am getting above mentioned error.
Here I have attached my screen shot of the error.
Could any one Please guide me how to solve this error.
I am using Kinesthesia kinect driver which generate U24 Bit RGB Image and I want to convert it in IMAQ Image type, But I am getting mentioned error.
But when I am not using the vision acquisition and vision assistant then every thing is fine means there is no any error which I have attached in attachment 2.
Please guide me how to solve this problem.
Thank you very much.
Message 1 of 22
(9,827 Views)
Create extra IMAQ create or IMAQ copy. The image you have created "untitled" might be overwritten or processed in Vision Assistant.
-Give proper name,instead of untitled.
-Cannot see the code properly, no dataflow maintained 😞
-Where is the image out from type cast going?to Vision acquision or Assistant?
-Please use error wires.
uday
Message 2 of 22
(9,822 Views)
Thank you very much for quick reply.
I follow your instruction but it give me still same error.
here in attachment I have attache screen shot as well Vi so you have a look.
thank you very much once again for help and time.
Message 3 of 22
(9,818 Views)
Image type for IMAQ create?
-Where is the Img Dst Out going from IMAQ type cast? to Vision Acquisition or Assistant?
-You shouldn't keep wires hiding!!!!
uday
Message 4 of 22
(9,816 Views)
Hii,
Here In attachment I have attached screen shot.
Image Dst out going to vision Assistant.
thank you very much for your help.
Message 5 of 22
(9,808 Views)
Got it. Are you getting the error in first iteration?
-Probably not. Becuse after first iteration, You connected RGB(U32) output to Image Dst of Vision Assistant(Why?), Can i know what operations you are using in this?
-If you connect Imag Dst as this image, the output of Vision Assistant will overwrite this image based on the image processing you are doing inside it.
-In the other case, where Vision assistant and acquisition are not used, this problem will not occur because you are not overwriting that same image.
uday
Message 6 of 22
(9,792 Views)
Thank you for your reply.
you are right , that i am getting error form the second iteration.
i want to make simple program for color detection in attachment I have attached screen shot of vision assistant.
what should I do to solve this error.
becuase for comparision operation I need both image files, am I right?
thank you very much once again for time and help.
Message 7 of 22
(9,781 Views)
There it is, You are converting the RGB(U32) image to grayscale by extracting one color plane which is the reason you will get the error.
-You haven't answered my other question. WIll you use this RGB(U32) image for processing or the image from Image Acquisition?
-If it is Kinnect image, connect this to Img source and create new IMAQ create(Grayscale) for Img Dst input of Vision assistant.
uday
Message 8 of 22
(9,775 Views)
Thank you Uday for reply.
Sorry for not giving ans.
I am using RGB(U32) bit image which is coming form the Kinect for Image for processing.
I dont know, if i understand your quesiton correctly or not.
but I am planing to use kinect for color or templet detection purpose. for that i just give its out put to vision assistant.
could you please explain second point.I dint get it.
thank you very much for your kindly help.
Message 9 of 22
(9,771 Views)
-I am not sure of express VI. But both extract color plane and pattern match both you can try them in labview itself.
-Try connecting Image output of IMAQ typecast to Image In of Vision assistant. Use IMAQ Create and create grayscale image and connect it to Imag Dst of Vision assistant. But i am not sure of this process becuase i dont know whether Vision assistant will take image directly or not.
-Then directly use pattern match and color plane extraction also in labview without vision assistant.
uday
Message 10 of 22
(9,766 Views)
