serial for labview
I check the communication by shorting the Tx and Rx pins, the transmitet data receving ok.
So the problem must to be in electronic load himself.
I still traying to understend why the Hiper terminal work fine and labview no 😞
Maybe it possible transmit char by char in labview like in Hiper terminal.
Message 11 of 26
(2,384 Views)
You have to change the Termination character settings. Default value is Linefeed.
See picture:
André
Message Edited by andre.buurman@carya on 09-04-2007 03:59 PM
André (CLA, CLED)
Message 12 of 26
(2,378 Views)
I don't now where i mistake , but i tray almast every devices that i can find for sireal communication , no 1 work
😞 this is the end?
HELP!!!!!!!!!
Message 13 of 26
(2,361 Views)
I can't view what you did because you posted your VIs in 8.5. It's important to send the correct termination character. In the basic example, there is the \r\n control codes at the end of the command string. These are the CR and LF codes. Are you including these with the command? When you write your own VI, you have to right click on the string control/constant and select '\' Code Display. Did you do this?
Message 14 of 26
(2,353 Views)
Don't they have a LV driver at this site?
André
André (CLA, CLED)
Message 15 of 26
(2,349 Views)
Vaj said:
The command that i try: *IDSN?     LOAD ON      LOAD OFF
Applying the comments of Dennis to your previous post.
It will become(string in code display mode):
*IDSN?\r\n   LOAD ON\r\n   LOAD OFF\r\n
André
André (CLA, CLED)
Message 16 of 26
(2,344 Views)
Finaly some progress (:
I take string to write ( componet) from else project and connect it to Visa write in pin for string.
Magicly this is work.
Before this i use string box , i produce it by right click on pin in Visa write -->create-->....
The question of million dollars is: "Why this is no work ? And i don't anderstend the difference between 2 cases".
Message 17 of 26
(2,323 Views)
See my answer above. Right click on the string control in the shipping example. It has '\' Code Display enabled. Right click on the string control when you select Create Control. It has Normal Display.
Message 18 of 26
(2,298 Views)
Hi again to every one1
I attach vi file and jpeg pic of part of the circle.
I have 3 buttons in front panel: current out , voltage out and power out. By pressing the one of the buttons i send unique command and after this command i tray to read answer from port.
The problem is that i read wrong data or button is stack (and labview too) to few seconds. some times i read all message or part of message from last tray of button press.
Message 19 of 26
(2,264 Views)
With serial communication first write, then wait and then read what is available on the port. Much like
PS. use '\ codes display' for the new line character.
Bart Boshuizen,
www.morechemistry.com
Message 20 of 26
(2,243 Views)
