serial port read and write
i ll take a look at the way you scan the word and answer your question
the chance to keep up is better because if your not flushing the serial port, data should be present
and you allow more data to come in to SCAN(search for a string), and while it (rewrite a scansearchblock.vi) is running
your readserial.vi  is reading a new block of data
then you will not be limited at the speed of scan,
Message 11 of 17
(923 Views)
Message 12 of 17
(922 Views)
this is a quick modif of you vi
1. add shift registers and redirect string wires
2. little modif in search (scan.vi) a -1 as offset means the string is not present(faster and save one vi)
Message 13 of 17
(921 Views)
hi,
Tried to look at the files you sent me but i am only using labview 8.2 if you could please post them again in 8.2 that would be great
Thank you
Message 14 of 17
(900 Views)
give me 5 min.....
Message 15 of 17
(895 Views)
Message 16 of 17
(891 Views)
Still got the same problem with opening the file
Message 17 of 17
(878 Views)
