set Colormap to spectrum.vi missing
I seem to be missing this VI. Is this a VI that should be included within LV 3D graph properties ?
Thank you.
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(3,312 Views)
Accepted by abikutn
Hi abikutun,
I have one question, are you talking about the Power Spectrum.vi? If that is the case it is located in the Spectral Analysis VI’s and you only require LabVIEW Full Development System. If you are missing this VI, you can try a LabVIEW reinstall process. If this is not the case, I would like to know more information about your application.
steve.bm
AE | NI
(3,307 Views)
Yes I got it.
Abhilash S Nair
LabView Gear:
(3,304 Views)
I am also missing this file. I work with Labview 11.
(3,198 Views)
Did you try the above steps suggested by Esteban?
Kevin S
Applications Engineer
(3,172 Views)
Yes but nothing came of it. In the end I didn't need the file.
Thanks anyway.
(3,109 Views)
