set VISA read sync globally
From an LabVIEW application that I am working on, I need to set the Visa Read to be syncrhonized.  From the context help file, I learned that I can right click on the Visa Read VI icon and set the attribute.  But, I want to ask if there any way to do it globally so that every VISA Read is behaving this way?
I am using LabView 8.5
Thanks.
Peggy
(2,976 Views)
Hello PeggyC
Once you have placed the vi on the block diagram and right click on it select the Synchronous I/O mode to the one you want and then select the vi and copy and paste it wherever you want it and it will have the same properties for this mode. I am not really sure you can do it programatically to all of the VISA read vi's that you have on your application.
"everything is achieveable through technology'
(2,937 Views)
