set resolution
Hello
I have a Vi attached. I was wanting this Vi to select an image and resize the resoultion to 100x100 then display the image in the front panel. I have read lots on scale factor but this dosen't seem to alter both to 100. Any help would be appreciated.
Craig
(3,988 Views)
If you want to stretch an image to 100x100 that will require some extra work, but you can quite easily scale the picture so the largest dimension is 100.
(3,979 Views)
Don't suppose you could post this Vi
Craig
(3,972 Views)
Accepted by Craig1988
It is a Snippet so you should be able to drag it to your BD.  Depending on your browser, you may have to drag it to your desktop first and then onto a BD.
Just in case, vi attached.
(3,965 Views)
