setting up a queue with this vi
Can anybody tell me how to set up a queue for this vi that I created?  I have 2 devices under test and I do not want them running at the same time, when DUT 1 is running DUT 2 shouldn't vice versa.  I do still want it so the operator can push both start buttons at the same time though.
Message 1 of 8
(3,549 Views)
Accepted by tech11
I've tried to change your VI but was way to big for my screen and also a little bit messy.
Take a look in this example that I've made for you. You can adapt your VI in the same way.
Paul
Message 2 of 8
(3,541 Views)
Sorry, I can't open this, your version of labview is newer than mine, i have labview 9.
Message 3 of 8
(3,537 Views)
Try my example, made in LabVIEW 9 SP1.
It's really quick and dirty, so if you use it you'll need to refine it. One big thing I'd do with it if I were you is make both of the enums in the cluster type defined, and make that cluster itself type defined.
Message 4 of 8
(3,532 Views)
Message 5 of 8
(3,527 Views)
So it worked for what you need? That is what you want to accomplish?
Message 6 of 8
(3,525 Views)
Yes
Message 7 of 8
(3,523 Views)
I've rewritten it in 8.5.
You should be able to open it now.
Message 8 of 8
(3,517 Views)
