04-09-2010 08:54 PM - edited 04-09-2010 08:58 PM
Ravens Fan wrote:Actually, you have a VI, not a snippet which is a new item that allows actual VI code to be bundled with a screenshot in a .png format.
The problem is that you have a cluster of arrays. Looking at the help file for the Create RT FIFO, I saw this "Note If you use a Real-Time FIFO to transfer waveform data, the variant element of the waveform does not transfer because variants are variable-sized and therefore incompatible with the Real-Time FIFO". I think it applies in your case as well because a waveform is just a special cluster that contains an array.
Thank you Ravens....- We gotta meet-
will you be in Mn anytime >
