several acquisition in one chart
Hi
I want to draw several acquisition in one chart.
That means if I push the first button I get a sine wave that begins on the left of the chart. When I push the second button the acquired data are displayed as a second sine wave beginning on the left of the chart again. and so on for the third button.
Any idea how to that?
Yves
(2,896 Views)
Hi Yves,
you can set the t0 of every channel to the same time so that they all start on "the left side".
Hope it helps.
Mike
(2,883 Views)
Thank you for your help.
I have not found the wayto do that. How can I do that.
But in fact I have only one acquiring channel. I wish to have three lines - the first line is drawn when I push the first button. When I set this button off, the line drawing stops. After this I push another button button and a second line starts to be drawn, from the left. and so on.
Yves
(2,867 Views)
Hi Yves,
how do you define which is the first channel? What happens if all three buttons where pressed one time, one after the other? Do you want to clear the chart and start from the beginning?
Mike
(2,865 Views)
Hi Mike
Well with first channel I mean the first button. It have only one acquiring channel.
The buttons will not be pushed together. The chart will be totally cleared automatically after ten minutes. Or partialy if a button is pushed.If everything runs as expeted I get a chart with 3 lines starting from 0 on the x-scale. The lines might even have different duration.
On the attached picture you "see" that the button 3 line is still growing.
Yves
(2,850 Views)
Hi Yves,
try the attached example, please.
Hope it helps.
Mike
(2,846 Views)
Thanks Mike
Exactly what I expected. I should have found the solution on my own. But....
Thanks alot
Yves
(2,825 Views)
