shadow lines from indent
Hi
Attached is a view of a FP. I have an indicator (circled) that I would like to remove the shadow lines from, so that the numbers have no outline whatsoever (if doable).
The file is png format, so I hope I'm not going to get somebodies ire up....if I do.....my apologies.
Ray
(3,072 Views)
Accepted by rayclout
Ray,
PNG is the preferred format for image files. So, thank you.
The easiest way to get a control or indicator to have invisible borders is to use the Classic controls.  They do not have the shading effects and can readily be colored Transparent.
Lynn
(3,062 Views)
Thanks Lynn
That'll do it
Regards
Ray
(3,058 Views)
