shared variable engine network published source issue
I am attempting to use the shared variable engine to share some simple stings over a network between a Windows 7 computer and a Windows XP computer.
I got through the shared variable example just fine and can share variables between VIs on a single computer. When I open the shared variable engine, it shows the client and server variables that are shared on the local computer. I then create a new process, and attempt to define a new variable, and the Shared Variable Property screen comes up. I attempt to "Bind to Source" and click browse, and see the computer name I am attempting to connect to. However, when I click it, it stalls and I cannot expand the computer to find the variable I am trying to bind to. What am I missing?
Thanks, Arron
(2,708 Views)
Is there at least a LabVIEW runtime on the second PC ? The remote machine has to support shared variables.
(2,706 Views)
Arron,
This document may be useful in helping to setup your network shared variables. Take a look at this and see if you have followed all the outlined steps in setting up a network shared variable.
http://zone.ni.com/devzone/cda/tut/p/id/4679
Let me know how this works for you.
-Nick-
Nick C | Software Project Manager - LabVIEW Real-Time | National Instruments
(2,690 Views)
