shared variables crio RT not working after compile
Hello Jeff, the document you mentioned has been updated.  This document is really only a workaround to prevent the RT system from haulting upon deployment.  It is not necessary to have two copies of the variables in the project for the variables to work.  Hope this helps!
Message 21 of 22
(901 Views)
Hi. In my case (same problem), I disconnected type definition for some Shared Variables (custom). Than I recompiled and rebuild.
Message 22 of 22
(528 Views)
