show a message over the front panel
I want to show a message over the front panel, saying for example "This is a demo version".
So I use a string indicator, and I made its background transparent.
The problem is that when I click with the mouse over this message, the indicator takes focus (obviously) and so I can't access to the objects behind it.
How can I have a message "over-impressed" the front panel without loosing the ability to click on the front panel objects behind it?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 1 of 17
(3,951 Views)
Hi Vix,
you can read the event from your string indicator and send it to the object behind it.
Hope it helps.
Mike
Message 2 of 17
(3,949 Views)
Hi Vix,
you may use a panel background picture to simulate a "watermark" ...
Message 3 of 17
(3,944 Views)
I know how I can read an event from the indicator, but I don't know how I can send it to another object...
Vix
Using LV from 7
Message 4 of 17
(3,938 Views)
You would need to use User Events. There's a shipping example that shows how to use User Events. However, I think having a background picture, as GerdW  suggested, is the easier solution.
Message 5 of 17
(3,923 Views)
If I use a background image, the front panel controls hide the message, but I want the message partially hide the controls, instead.
I see this nice feature when I installed the evaluation version of LabVIEW 8.6 (see attached)
Vix
Using LV from 7
Message 6 of 17
(3,918 Views)
I doubt that's done with any kind of control or indicator or decoration. I suspect that's being done directly in the window's paint event (or its equivalent on other platforms) after all other front panel content is drawn.
You can probably hook into an OS call to draw your image on the front panel's graphics pane.
You can also submit a suggestion to the Product Suggestion Center
Message 7 of 17
(3,894 Views)
Hi Vix,
you can disable the string control so that it will not focus even if you click on it. In order to set this property, you have to right click the string control and select Advanced >> Enabled state >> Disabled.
In attachment there is an example of this behaviour.
Serena M.
NI Application Engineer
Message 8 of 17
(3,859 Views)
Sorry, this is the right one!
Serena
Message 9 of 17
(3,853 Views)
Just saw this post.
Just right click the control navigate to advance>>Enabled state select the disabled option (not disabled & greyed).  This option will restrict the control from receiving the mouse clicks from user and will not get the focus.  Easy oneSmiley Happy
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
Message 10 of 17
(3,846 Views)
