waveform vs. 1D array of waveform for subVI connection
I have a subVI that I'm modifying so it can accept a waveform type input (it used to take a 2D array of double). I have created the indicator of type "waveform" on the front panel of the subVI, and connected that using the terminal diagram. However, the DAQmx acquisition block I need to connect to it (from the parent VI) outputs a 1D array of waveform, and hence it the two are not compatible. Can someone please tell me how to make the indicator into a 1D array of waveform type, rather than just a waveform type?
Claire.
(3,542 Views)
Accepted by topic author CFJ
Place an array container on the front panel, drop the waveform control into it, and connect that to the connector pane. See how far you get. 😉
(3,533 Views)
fantastic!!! I didn't know that drag and drop worked in Labview.
Thanks very much altenbach 🙂
one stumbling block down...many million more to go tonight I expect
(3,529 Views)
