show a vi that is normally hidden
Hi Guys,
               i have a VI that has a subVI constantly running in the back ground, but i want a button on the main VI to allow a user to make the subVI visible, then when the user closes the sub VI i want it to go back to running in the background.
So to clarify i want the SubVI to run all the time out of sight but allow a user to show/hide it from the main VI.
I have looked at property nodes but i cant create a reference for a sub VI.
Any ideas >?
thanks, zac
(3,406 Views)
Accepted by Zac_Acal
Easiest would be to place a static VI reference (application control palette), and browse for the correct VI. Then use an invoke node with  FP.open method.
(3,403 Views)
Thanks, works great.
(3,381 Views)
Just one question...
Because the staticVIreference is looking for a path, does that mean that when i install the .exe version on another pc it wont work unless i copy that vi into that path on that pc, or will all that be taken care of in the compile ?
Cheers, Zac
(3,378 Views)
Zac_Acal wrote:
... or will all that be taken care of in the compile ?
Yes, everything will be taken care of automatically when you built the application.
(3,372 Views)
