simple 2x2 matrix
...simple, but not for me!
How can I write attached expressions in labview?
(5,189 Views)
Hi Lesterino,
using Solve Linear Equation:
(5,170 Views)
You don't say what version of LabVIEW you are using.  The most recent versions of LabVIEW have Matrix functions on the Array Palette.  Have you tried them?  Is your version of LabVIEW "too old", i.e. before the Matrix functions were introduced?
Bob Schor
(5,158 Views)
Hi Bob,
the version is 2013.
(5,110 Views)
Hi GerdW,
thank you!
how can I get H?
How can I write the product (or a sum) of a sequence of terms directly? is it possible without using a for loop?
(5,100 Views)
Well, LabVIEW 2011 (which I have running in a VM here) and LabVIEW 2015 have Matrix functions on the Array Palette, so LabVIEW 2013 should have them, too ...
Bob Schor
(5,096 Views)
if you want to do some symbolic mathematics, labview is not appropriate tool for this one but it is not means that you can not do it there is some symbolic example in labview for that but matlab is more better for this one
but for functions like matrix multiply or inverse matrix and determinant calculation you can use linear algebra tool you can find them in mathematics branch
(5,084 Views)
