simple moving average problem using filter express vi
I am having some problems with filter express vi. I am trying to use it as moving average.
I am feeding in a simple array of 10 numbers with the half-width of 2. But on the output, I don't get the correct filtered result. Is there something I am doing wrong here?
I have attached the sample VI I made for testing out the moving average function.
Any help is appreciated.
Message 1 of 8
(6,126 Views)
The filter Express vi does not compute a simple moving average.  It applies a smoothing filter to the data.  it is bit different.
A simple moving average can be realized with this snippette:
Message 2 of 8
(6,115 Views)
Hi Jeff,
I was trying to construct the VI according to the image you posted, but I am not sure what NaN stands for? Also, what's the subVI beside it (orange one with the arrow pointing left)
Message 3 of 8
(6,098 Views)
NaN stands for Not a Number.  its a special case for IEEE 754 floating point numbers as are +/-inf.   The Feedback Node can be found on the structures pallatte.
Of course, that png shown is a "snippette."  just right-click it copy it paste it to your desktop and drag it onto a block biagram.  "Poof" the code is written! and hovering over the items with Ctrl+H on will take you right to the help file.
Message 4 of 8
(6,085 Views)
Or you can use PtByPt averaging.  Found in Signal Processing >> Point by Point >> Prob & Stat >> Mean
Sorry, mine is not a snippet.  Haven't installed that yet. 🙂
aputman
Message 5 of 8
(6,067 Views)
I might be wrong, but I think the snippet is already a built-in Labview tool;
Here's a manual:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2PkCAI&l=en-US
Alex
Message 6 of 8
(6,062 Views)
Not equvallent and will yeild strange results if number to average changes.  Placing Number to average outside the loop yields equivallent results(Given the same "Random numbers").  just a bit less Rube-GoldbergySmiley Wink
(Your Code: underneith...):
Smiley Surprised
Message 7 of 8
(6,056 Views)
Thanks for the help everyone.
Looks like I got that part working now
Message 8 of 8
(6,027 Views)
