LeCroy 64Xi with Ethernet
Hello i'm having issues in the configuration of this instrument.
I downloaded the drivers from the site and put them in the folder \National Instruments\LabVIEW 2012\instr.lib
but i want to use this instrument also using the SCPI commands.
The first thing that I see is that in MAX I don't find the instrument in the Remote Systems. I did right click and created new but when I set the ip (192.168.32.55) but I got error "Unable to inizialize connection to remote target(s)".
Same problem if I try to write in the example VIs VICP::192.168.32.55
I'm sure the IP written before correct because I got no error with the ping in the prompt C:\
I also tried to follow the guide I found here:
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Lecroy-WaveRunner-64Xi-Using-LabVIEW/m-p/1198...
the problem is that I'm strucked when it says: "from the dropdown menus select:  Tools/NI VISA/VISA Options..." i don't have these options in the Tools window.
Where is the mistake?
(3,064 Views)
Check the below picture very specific to your query:
VISA -- Properties
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,051 Views)
@Ashwani The easier way into the tool is through the menu
@inuyasha84:  From MAX  use Tools>>NI-VISA>>VISA Options:
(3,046 Views)
