Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
simple popup control message
scott-e
Member
11-07-2003
09:58 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I need to make a simple user instruction message
popup just prior to execution of a sequence with a simple yes/no booleen button in it or even a simple popup message that can be clicked on to remove. Thanks
0
Kudos
Message
1
of 3
(2,883 Views)
Reply
Re: simple popup control message
altenbach
Knight of NI
11-07-2003
12:14 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
What's wrong with the "Two Button Dialog" found in the Time&Dialog palette?
Should work just fine for this.
LabVIEW Champion
1
Kudo
Message
2
of 3
(2,883 Views)
Reply
Oleg
Active Participant
11-07-2003
12:15 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
you can use "One Button Dialog.vi" and "Two Button Dialog.vi" from "Functions->Time & Dialog" palette.
Good luck.
Oleg Chutko.
1
Kudo
Message
3
of 3
(2,883 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
