simple way to save array cluster for file
Accepted by topic author sherzaad
finally got a working solution. its based on geokim98 reply
reason I did it that way is so that user does not need to input ".csv" extension with the filename :fghdfh.jpgone thing I noticed though... there is an extra column of zero's that appear at the end... anyone any ideas why?
Message 11 of 14
(1,672 Views)
then do mark him as solution also, or at least give him kudos (the star at the bottom)
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 12 of 14
(1,664 Views)
agreed. done already! 😉
Message 13 of 14
(1,659 Views)
regarding your last question,
it would really help if you don't post images of code, but code aka VI
you might want to skim over this post too
https://forums.ni.com/t5/Community-Documents/Unofficial-Forum-Rules-and-Guidelines/ta-p/3536495
regards
Message 14 of 14
(1,649 Views)
