simulation interface toolkit?
I had test the (.so) file that use MIT example ( MIT Get Model Information.vi ),it can respond the shared library informations,I think it's ok!!
After I back office ,I will test function using MIT & deployed it to 9068...
I must offer my heartfelt thanks to you!!!
Message 21 of 32
(3,691 Views)
I would suggest using the MIT Inport and Outport example found in the example finder under Toolkits and Modules » Model Interface » MIT Inport and Outport.
The initialization section of the VI can be seen below. You should be able to execute this VI on the target and point it to the .so model in the filesystem, Then depending on what inports and outports you want to use you can modify the example to find the offsets of them in your model:
The loop part of the example looks like this:
You can see how the model gets executed every iteration and can be tied to other inputs and outputs.
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Message 22 of 32
(3,691 Views)
We posted back at the same time Smiley Very Happy
I'm glad that everything is working!
Message 23 of 32
(3,688 Views)
Ha..
you reply so soon!!
I already test it use MIT Tool!!
But when I add Take Model Time Step.vi ..LabVIEW always crash!!
I think maybe it need work in Linux platform...
Message 24 of 32
(3,686 Views)
Yes, your .so is only executable on an ARM based Linux machine, so you have to run it on the 9068.
Alternatively you could compile the model with a different TLC file (the Pharlap one) and make a DLL that would work on your windows system (it wouldn't work on the 9068 though).
Message 25 of 32
(3,681 Views)
Hm...I had compiler this .mdl with Pharlap two years ago,and deployed in PXI successfully!
Thanks!!!
Message 26 of 32
(3,676 Views)
hi...I want to talk you...I deployed .so to 9068 using MIT function that all goes well!!
Thank you again!!!!
I develop HIL system application..
But 9068 calculate too slow,I need more fast CPU...Maybe the only way is deploy on PXI system.
Message 27 of 32
(3,658 Views)
Hi...Sir!!
I have a question ...when I installer the 2014 eclipse package...
I can't find the path" <National Instruments>\Eclipse\toolchain\gcc-4.4-arm\i386\bin\" .....
But the 2013 eclipse package version had the folder!
Could you tell how resolved ..
thanks!!!
Message 28 of 32
(3,640 Views)
Well, for one the 2014 Tools updated the GCC version to 4.7.2.
This setup document does indicate the paths you're supposed to set within eclipse for the different targets:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHR7CAO&l=en-US
Specifically section 4 item 14 notes:
In the Cross compiler path text box, browse to the location of the correct compiler for your target as specified in the following list:
(ARM-based targets, 2013 software stack) \<National Instruments>\Eclipse\toolchain\gcc-4.4-arm\i386\bin
(ARM-based targets, 2014 software stack) \<National Instruments>\Eclipse\14.0\arm\sysroots\i686-nilrtsdk-mingw32\usr\bin\armv7a-vfp-neon-nilrt-linux-gnueabi
(Intel x64-based targets, 2014 software stack) \<National Instruments>\Eclipse\14.0\x64\sysroots\i686-nilrtsdk-mingw32\usr\bin\x86_64-nilrt-linux
So, if you're compiling with the 2014 stack on a 9068 (ARM based) you'll choose the <National Instruments>\Eclipse\14.0\arm\sysroots\i686-nilrtsdk-mingw32\usr\bin\armv7a-vfp-neon-nilrt-linux-gnueabi path.
Message 29 of 32
(3,615 Views)
OK~~
I also need fix the Prefix path:"arm-nilrt-linux-gnueabi-"
It would be OK!!
Thanks a lot!
Message 30 of 32
(3,608 Views)
