simultaneous AI AO on one board
I'm working with a DAQCard-1200 and I must write out Analog Data (Waveform) to one chanel and read the reaction of the Instrument simultaneos from another channel, may someone know how I can solve this problem.
thanks for help.
(3,064 Views)
If you are using LabVIEW 6.1, use the Example Finder (Help>>Find Examples...) and search for simultaneous. You'll find "Simul AIAO Buffer(1200).vi" which should get you started.
If you're in an earlier version of LabVIEW go to examples\daq\anlog_io\anlog_io.llb to find the same example.
Doug
(3,064 Views)
