03-13-2006 03:44 PM
03-13-2006 04:03 PM
Joe:
I think the cb-68 is just a connector break out box that accomodates many different DAQ cards. Do you know the model number of the DAQ card itself?
05-29-2007 11:25 PM
Hai, i just bought a CB-68LP Connector but i don't understand where the input (pin number) is and where the ouput (pin number) is . I have searched through NI site about the pin information, number of channel but i can not find it.
For instance i want to measure a DC Voltage from power supply ex 12 Volt. And i want to acquire that voltage to my computer through CB-68LP. What pin i have to use to connect +12V and ground?
ANyway, my model number of DAQ is 184479E-02. Thank alot you for your information.
05-30-2007 08:39 AM
The connections you use depend on the DAQ board and the documentation that came with the DAQ board explain the pinout. The CB-68 is just a dumb terminal block. There is a 1:1 correspondance between the pins on the CB-68LP and the pins of the DAQ. You provided a part number instead of a model number (i.e. PCI-6225) and I have no way of cross-referencing that.
I hope you bought a DAQ board that has the input range necessary for +12V.
05-30-2007 01:46 PM
05-31-2007 01:37 AM
Thank you for your informationn and answers but i still confuse about the difference analog I/O and Digital I/O. Is that mean the pci 6601 can not measure the analog input? Does pci 6601 have ADC (Analog to Digital Converter)?
Yesterday, i tried to measure a room temperatur with termocouple (T Type). I connected the Termocouple to the CB-68LP (dumb terminal block) and i use DAQ Assistant in Labview. But when i opened the properties of DAQ Assistant and then i clicked analog input, there was no physical channel supported. What should i do so that the analog voltage from termocouple can be obtained?
Please help me for this problem. Thanks alot.
Darmawan
Reseacher at reseach center of Quality and Testing Technology
Indonesian Institutes of Sciences
Indonesia
05-31-2007 10:27 AM
05-31-2007 03:28 PM
05-31-2007 03:34 PM
05-31-2007 04:35 PM
Just to clarify Jmarotta asked about analog I/O, which he is able to do since he is using the PCI-6036E. It was Darmawan who provided the part number for the PCI-6601, which does not support analog I/O. If there are further questions about this issue, please post back.
