 martper
			martper
			03-06-2007 04:31 AM
We have tried the Simultaneous sound Io.vi but have experienced problems. We are using the microphone input and speakers on the same sound card. The number of samples/ch is 5000 and the sample rate is 44100 S/s. Number of channels are 2 and bits per sample is 16.
When running the program we get a error message (4823) after some time (sometimes 3 seconds and sometimes after several minutes). If the number of samples/ch is increased, will the program run a longer time before failing. We tried to run the program on a computer with two sound cards and then it did not fail.
The other problem is that it dose not sound good. The speakers plays the input signal with some kind of sparking sound (glitches? choppy?). After some time this sound dissapere and it sound good but can come back again. I have search the forum for simular sound problems but have not found anyone with this kind.
Best regards, backsatge68
			backsatge68
			03-12-2007 03:14 PM
03-13-2007 02:23 AM
 backsatge68
			backsatge68
			03-13-2007 04:07 PM
 Hans_PPPL
			Hans_PPPL
			03-15-2007 10:01 AM
I have been having the same issue getting a 4823 error when running Simultaneous Sound IO vi
M-Audio Delta 44 Sound Card
Dell Dimension 360 PC
Windows XP SP2
LabVIEW 8.2
20,000 Samp/Ch
4 Channels
44,100 S/s
16 Bit resolution
I can get the vi to stop on 4823 error at will by opening mail in Microsoft Outlook although it has stopped on it's own as well.
I am trying to develop a 4 Track Record - Playback application to replace a Tascam 234 Syncaset 4 track recorder. I'd like to have "confidence monitoring" while recording and thought a vi like the Simultaneous Sound IO vi would do the trick.
Is this a problem with the dll in Sound Input Read vi (which generates the 4823 error) or an issue with the Sound Output Write vi?
Sure would like to hear of any fixes – thanks.
 backsatge68
			backsatge68
			03-19-2007 05:15 AM
 Hans_PPPL
			Hans_PPPL
			03-19-2007 08:02 AM
Backstage,
Thanks for your reply and link to the “French” discussion of this problem.
I stumbled on “French” discussion on Friday and had the same questions as you. Why 16536 samples and why divide by 3?
I suspect that that configuration works best on Véronique’s PC.
I have tried her vi (Simultaneous Sound IO_works.vi) and on my PC it still get the 4823 error.
I have run out of time and must move on to other projects but will check back on this and the “French” discussion periodically.
No need to apologize for your English as my French is much, much worse. (http://www.freetranslation.com/)
Hans
Backstage,
Merci pour votre réponse et relie à la discussion « française » de ce problème.
J'ai trébuché sur la discussion « française » vendredi et questions pareilles eues comme vous. Pourquoi 16536 échantillons et divise pourquoi par 3 ?
Je soupçonne que cette configuration travaille mieux sur Véronique PC.
J'ai essayé son vi (Simultaneous Sound IO_works.vi) et sur mon PC il obtient toujours la 4823 erreur.
J'ai manqué du temps et dois déplacer sur aux autres projets mais vérifierai de retour sur ceci et la discussion « française » périodiquement.
Aucun besoin de s'excuser de votre anglais comme mon français est beaucoup de, beaucoup pire. (http://www.freetranslation.com/)
Hans
 asdfwww
			asdfwww
			04-17-2007 12:09 PM
 backsatge68
			backsatge68
			04-17-2007 12:48 PM
 asdfwww
			asdfwww
			04-20-2007 04:55 AM - edited 04-20-2007 04:55 AM
Message Edited by asdfwww on 04-20-2007 04:56 AM
Message Edited by asdfwww on 04-20-2007 04:57 AM
