sine to ttl conversion
        I want to convert
                                            1) a 10MHz sine wave to 10MHz TTL
                                          2)a  180MHz sine wave to 180MHz TTL
Is there any circuit or IC available for the above two conversions independently or together.
Regards
RobinHood
(3,895 Views)
Hi Robin,
why did you post twice? Nevertheless this question isn't LabView related, isn't it?
I would suggest a "simple" (180MHz Smiley Wink ) comparator circuit using OpAmps. You could adjust amplification and other parameters, that (may) come into play too...
Message Edited by GerdW on 11-17-2009 09:59 AM
(3,887 Views)
Hi GerdW,
                Don't call me Robin, call me Robin HoodSmiley Sad
Regards
RobinHood
(3,854 Views)
Robin Hood wrote:
Hi GerdW,
Ummm... Ooookaaaayyy.... Smiley Tongue
(3,841 Views)
GerdW wrote:
Hi Robin,
If only we were so lucky.
Post 1.
Post 2.
Post 3.
Post 4 (this one).
STOP FLOODING THE MESSAGE BOARDS.
(3,836 Views)
Hi smercurio,
I usually only look into the LabView forum, so I missed the other two postings...
@Robin:
When you insist on your last name you should have set your nickname to "RobinHood". I usually only use the first name for addressing "direct" answers Smiley Wink
(3,830 Views)
GerdW wrote:
Hi Robin,
As GerdW said what I posted isn't a labview related question.I was looking for an apppropriate board.so, I posted on
multiple boards hoping If could get answer from any one of tyhe boards.Sorry for the inconvenience caused.
Regards
RobinHood
(3,806 Views)
