11-17-2009 02:24 AM
I want to convert
1) a 10MHz sine wave to 10MHz TTL
2)a 180MHz sine wave to 180MHz TTL
Is there any circuit or IC available for the above two conversions independently or together.
11-17-2009 02:58 AM - edited 11-17-2009 02:59 AM
Hi Robin,
why did you post twice? Nevertheless this question isn't LabView related, isn't it?
I would suggest a "simple" (180MHz ) comparator circuit using OpAmps. You could adjust amplification and other parameters, that (may) come into play too...
11-18-2009 04:29 AM
Hi GerdW,
Don't call me Robin, call me Robin Hood
11-18-2009 09:02 AM
Robin Hood wrote:Hi GerdW,
Ummm... Ooookaaaayyy....
11-18-2009 09:05 AM
11-18-2009 09:35 AM
Hi smercurio,
I usually only look into the LabView forum, so I missed the other two postings...
@Robin:
When you insist on your last name you should have set your nickname to "RobinHood". I usually only use the first name for addressing "direct" answers
11-18-2009 10:42 PM
GerdW wrote:Hi Robin,
As GerdW said what I posted isn't a labview related question.I was looking for an apppropriate board.so, I posted on
multiple boards hoping If could get answer from any one of tyhe boards.Sorry for the inconvenience caused.
