I have been using the Sine Wave
Generator .vi for just a basic application to generate a sine wave with
adjustable amplitude, freq (100Hz+) etc etc
Recently I started
using the same vi but for an application using much lower frequencies
in the rage of sub 1Hz, eg 1e-3Hz.
But I have noticed a problem with
this, on the graph display the whole sine wave is not produced, only the
start of it (just the first second). I have tried changing the graph
properties and scale, and the sampling but I only get the output for the first second,
which just appears like a straight line. Can this be fixed? or is there
some other kind of problem?
I think the simplest way to describe what I am
trying to achieve is a sine wave, which completes one cycle in say 10
min or 1 hour.
How many samples are you generating and what is the sample rate? It sounds as though you may only be generating enough samples for the first second. The first second of a 1 mHz sine wave would look like a straight line.
I am not sure which sine generation VI you are using. Several variations have been developed over the years.
Most likely you will need to do the calculations yourself. Decide which parameters are most important to your application and then write your own VI which takes those parameters as input and have it calculate the values required by the Sine Generator, which becomes a subVI to your VI.
