skip waiting button
Hi all,
in my program I have a SubVI where the temperature for the test is settled and, optionally, there is a delay for the soak time (see atatchement).
During this delay, i would like to implement a "Skip waiting" button, so that the user can avoid it. The problem is that the execution waits until the "ok" button is pressed. I have also tried two parallel while loops with no success.
Would be great if somebody can suggest me an implementation.
Thanks!
Gatet
(3,448 Views)
Hi Gatet,
use an event strucutre. Use the timeout event and create an event for your skip button. Connect your timeout time with the event structure.
Hope it helps.
Mike
(3,434 Views)
Hi Mike,
That is a goog hint, but I was thinking in a dialog button (so that only appears during soak delay time).
BR, Gabi
(3,422 Views)
Hi Gabi,
you can solve it, if you create your own dialog from my example. Smiley Wink
Mike
Message Edited by MikeS81 on 08-25-2008 12:03 PM
(3,419 Views)
That makes sense...
Thanks Mike!
(3,373 Views)
