small project
Message 11 of 34
(809 Views)
Hi fan,
@soccerfan wrote:
However ii know a fiew hings about events stucture and that is what i used in this problem
Where exactly did you use the event structure mentioned by Bob?
It isn't visible in your image!
What's the point of using a while loop that iterates only once???
suggestion: use a type-defined enum instead of a combobox to select a predefined number of cases!
Why don't you write you want to implement a Darts counter algorithm!?
Message 12 of 34
(800 Views)
I love how solving this small project became primarily understanding what the project is haha. The 501 and 301 reminded me of something as well that I couldn't point out, well done.
@Soccerfan a couple of things:
  • Not everyone has the latest version of labview and will therefore not be able to open code from a more recent version. If you want people to help you debug something it is important to downgrade your code by "Saving for previous version" you VI:
  • As GerdW said, if you want to subtract multiple times a different number (and most likely check when you hit 0 or go back to the previous number if it is actually a Dart Game) you should definitely spend a bit more time understanding Event cases and I would also add State Machines. You'll see it's a lot of fun, almost more than playing darts.
Message 13 of 34
(788 Views)
I think he was referring to my snippet that used an event structure.
@soccerfan,
Learn to use the Event Structure. It is one of the most useful features when dealing with a GUI. Just play around with it. This might be one place to start: Event-Driven Programming in LabVIEW
Message 14 of 34
(776 Views)
You are right this is from a dart scoring sheet ( 501 and 301 gave it away). This is just a snippet that i pulled from my bigger project that uses a state machine . I did not want to show you the whole project that is a mess right now. I am interested only in the problem i mentioned earlie for now. I am sure more questions will follow about the whole project
Message 15 of 34
(761 Views)
Attached is my project , If you know about dart game and willig to help, i will appreciate it.
It is still in working process (i know it's a mess), The only part that seems to work now is:
-select player1 and 2
-select game
-Player 1  The 1st time you enter your score (ie 100 or any score  170 or less ) and that comes my problem for the next score
If you play darts you should know what i mean.
Come on Champs,,
Message 16 of 34
(761 Views)
@soccerfan wrote:
Thanks for your answer. You almost got it. I cosidere myself an intermadiate labview learner, i still have a long way to go. However ii know a fiew hings about events stucture and that is what i used in this problem
 Your figure shows a While Loop around a Case Structure.  An "Event Loop" is a While Loop around an "Event Structure".  On the LabVIEW Structure Palette, the Case Structure is the fourth item in the Structure Palette, with the Event Structure being the fifth shown.  Please learn about it, as it seems to be the "missing piece" in your understanding of the problem you are trying to solve.
Here is a simple example of an Event Loop.  You can ignore the Invoke Node on the left -- that's just there to reset all the variables on the Front Panel to their defaut values before the code runs.  Code this up or drag the Image to an empty Block Diagram (it's a LabVIEW Snippet, so it might magically become LabVIEW code).  See how it behaves when you run it (including understanding when and how you stop the program).  When you think you understand what is going on, try modifying the program by dragging the Number control outside the While Loop (so it is just "hanging out in the breeze" -- before you run it in this configuration, what do you think will happen?  Did it behave as you expected?  Why (or why not)?
Bob Schor
Message 17 of 34
(751 Views)
Thank you for your time, However that's not what i am looking for. Check my project that i posted earlier ( darts.app .vi) to have a grasp of what i am looking for.
Thank you again
Also, dragging the snippet did not work for me
Message 18 of 34
(744 Views)
Hi fan,
Unfortunately you failed again in providing a downconverted version of your VI.
Somehow you aren't able to read our messages or willing to follow them…
Message 19 of 34
(737 Views)
I did, i converted all the way down to version 9. What version do u want me to converted to?
Message 20 of 34
(728 Views)
