small runtime engine for newer labview versions?
Accepted by topic author JÞB
I gave it a try and was able to run my labview exe under the bare 2012 runtime which is about 28Meg in a zip file.  It was even easier than the  article suggested.  I unzipped the RTE installer, pulled out the "LabVIEW_Runtime_Engine_2012" component,  installed it on a VM and it worked!
Message 11 of 14
(1,426 Views)
Turns out I needed to add some functionality that required NI VISA.  The VISA installer is over 100 Meg but, after unzipping, I was able to pull out the bare VISA Runtime installer which is only about 12 Megs.
Message 12 of 14
(1,397 Views)
@chiraldude wrote:
This forum, (like the runtimes in this topic) is bloated and full of "eye candy".  It is not clear which credit box goes with which item.  I was just as surprised as you when I recieved an instant email from the forum saying I had accepted my own solution.
OT: You probably got a strange e-mail and wondered what happened.  I was reviewing a thread that linked here and noted the strange solutions that did not explain the steps taken to reach the desired effect.  I don't use Champion Powers often but, in the interest of clarity for the next user that wants to create a minimal installer I modified the solutions to this thread.
Message 13 of 14
(1,278 Views)
Message 14 of 14
(891 Views)
